How to disable dashpot
  • How to disable dashpot
    Just swapped a 4-1 and discovered that i now have mechanical time delay. How do I speed it up?
    Just back out the metering needle and/or plug it with a bolt. It is fine thread. 3/8 x 24
    ALL Files Scanned with MALWAREBYTES PREMIUM Version 3.7.1.2839 and AVAST INTERNET SECURITY Version 18.6.2349
    Time Dealy Stem.pdf
      Thx
        what exactly is mechanical time delay? this is the first time I have hearing this phrase
          If you have American A2s it's a valve that slows the speed of the dashpot going down. It was used on A pinsetters without time delay modules. If you have Japanese A2s imagine a dashpot in place of the rubber bumper. The adjustment was to screw the metering needle out to decrease delay and in to increase delay. Some mechanics screw the needle way out if they convert to electrical time delay but then the needle can sometimes leak oil so I like to replace with a bolt as Mickey said.
            ok cool, I wasn't to sure what that was.. I have jap a2s so that's why ive never heard that term before...
              Most of mine still have the time delay screws in the gearbox, but backed out enough to disable the delay.
              All my machines still have the master link on the plunger lever to the dashpot stem.
                Not all our dashpots work. The ones that do, are adjusted to take the slam out of the triggering mechanism.
                Oil in gutters
                C1 Pinout drawing
                Finished the C1 drawing.
                Thanks Felix.
                If you see any...
