A 2 Rakes
  • A 2 Rakes
    i have two machines that will allow the rake board to ride up and across the pin, bringing it back out as dead wood, any thoughts ?
    Coby
    ANYONE WHO HAS NEVER MADE A MISTAKE HAS NEVER TRIED ANYTHING NEW
    Your rake cam is out of adjustment.
      If you need rake adjustment guide, check this thread
      http://www.bowltech.com/forum/pinset...steve-stafford
      Mike Wilson
      Bowl-Tech Inc.
      MONITOR COLOR ISSUE!!
      Pin spot is off
