Broken key
  • Broken key
    Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
    Anyone wanting to have a guess at
    A) Which shaft?
    B) What part was the key under?
    C) What was the original problem?
    First correct answer receives 1 free game.
    A) 1:1 main shaft.
    B) Moving deck/scissor cam.
    C) Setting wobbly pins.
    And if I happen to be right, I ain't cashing in on the prize.
      Need some dimensions . Otherwise it could be from the fly wheel on a Cessna 152 4 Cylinder Air Cooled engine LOL
        A) 4:1
        B) steel gear that drives 2:1
        C) rake being driven, but 2:1 and 1:1 not or lagging and slipping way behind.
          Im going with stripperbolt and the 1-1 cam key.
          Thats the only key I have seen break up in pieces like that.
          But knowing its a Japanese version, you cant rule out anything.
            I see 2 correct answers but from different posters.
            Jap A2 box running at pie plate speed for 30 years, now installed on A model running at A speed. Problem it was causing wasn't constant but amnoying. I suspected the part this key was locking to the shaft to be the cause, and in one way it was but not how I expected.
            ‚Äč
              Everyone else scared to have a shot?
                Ok looks like anyone who wants to have a guess and pick up the prize has done so.
                The correct answers are
                A) 4:1 shaft
                B) The bronze gear
                C) The deck was knocking over pins when restanding them, most notably the 7 & 10 pins.
                MONITOR COLOR ISSUE!!
                Pin spot is off
