Clutch reset lever
  • Clutch reset lever
    I am at a center with old style 2 piece clutch reset levers, can I use the 1 piece no problem?
    you know we don't allow managers back here....
    yes
      There is really no reason to change them. It follows the extended cycle cam and gives more tolerance for the dashpot stop collar adjustment. It's more of a fine tuned adjustment with the newer A-2 style lever.
        You asked if you could use the one piece in place of the two piece clutch reset levers. Are the machines A's or A-2's? If they are still A's...then no, you can't change. If you have A-2's, you are golden.
        Super Bowl Funday!
        Qubica BES-X Lane Advertising
        Making TDM's adjustable.
