Need part numbers
  • Need part numbers
    The electronic catalog does not list the detail for these parts or I simply cannot find it.
    The pin that holds the clutch lever to the clutch yoke, the flat washer, and the snap ring.
    I do not use these stabilizer kits if it makes any difference.
    Never mind, found it in the Quality book
      For future reference, the original Brunswick parts book can be located as well. I keep 2 in my office.
        i have parts 1, 2 and 4
        1) snap ring or retaining ring.....part# 11-530015-000
        2) 7/16 flat washer.....................part# 11-190016-001
        4) pin..........................................part# 12-100168-003
        MONITOR COLOR ISSUE!!
        Pin spot is off
