Moving deck
  • Moving deck
    What is the best way to determine if a moving deck is bowed with it out of the machine and stripped down?
    Ignorance is Bliss!
    Flip it over and put a 4 foot level across the 7,8,9,10 area. If it's bowed it will be obvious.
      Measure gap from Stationary deck to moving deck in the middle and both ends
      The older the part, the STRONGER it is.
        I agree with Griz.
          If it is bowed enough, you will begin experiencing pin detection problems, (if not already), particularly with single pins in the bowed area of the moving deck. The old machines have a much "beefier" deck and typically don't experience any warping. I believe the Japanese and newer A2's have a fairly "light deck".
            Not to threadjack here, but can this check be done with the moving deck in the machine, or must it be removed?
              You can slide a straigh edge in from the side if it's not too broad but measuring from scissor to moving at the back can be done in for certain and it does not require room from the neighboring machine. Make sure the scissor is securely bolted with zero missing flat head cap screws.
              • Wheelinbob
                Moving deck....
                by Wheelinbob
                Just curious i forgot how many times is the Moving deck wound up and it is clockwise if i remember corectly...thanks Bob
                01-26-2007, 12:39 AM
              • JEFF KUHNLE
                MOVING DECK
                by JEFF KUHNLE
                HAD ONE OF MY MACHINES START ACTING UP. WHEN THE DECK GOES DOWN TO PICK UP STANDING PINS, THE MOVING DECK MAKES A SLIGHT FORWARD MOVEMENT. BEFOR DECK MOVES GENEVA ROLLERS ARE...
                08-10-2000, 01:30 PM
              • ndenbow
                moving deck.
                by ndenbow
                i have a moving deck that is binding somewhere and am looking for some input on where to look. it will not shift to the rear to set new pins. upper deck cable has been replaced...
                07-23-2013, 01:34 PM
              • KIM
                Moving deck
                by KIM
                a friend lost the cam followers for the moving deck. I remember seeing a procedure for winding the moving deck spring but can't seem to find it. Can anyone help?
                04-09-2006, 04:11 PM
              • gearhead
                Moving Deck question
                by gearhead
                While changing deck chutes i noticed that the moving deck moves left/right rather easily and quite a bit by hand,looking around i see nothing wrong,could the moving deck wheels...
                04-19-2003, 12:17 PM
              Qubica BES-X Lane Advertising
              Ball Damage at my wits end
              GS-X table bolts/stud
              Other that...
              1:1 shaft wear
