Jap a2 blows 2amp fuse
  • Jap a2 blows 2amp fuse
    unplugged everything from control box acc,reset,mgr cntrl, mask, pitlight....checked solenoid, motor, and mag clutch recepts still blows the fuse when i jump a&b....helpppppp????
    2amp fuse is on transformer high side.
    shorted motor contactor?
      Shorted rectifier, shorted transformer
        ive had a bad rectifier do the same thing
        Super Bowl Funday!
        Qubica BES-X Lane Advertising
        Making TDM's adjustable.
