Clutch whacked
  • Clutch whacked
    I cannot wait to go to Steve's school; however, Lane 17 decided to break off a clutch lever. The on-duty pinchaser replaced the lever and re-adjusted the clutch (he did this pretty well in the past). He said the clutch is rattling bad, still. If he adjusts it either way, it will not stop properly.
    So... what is eaten up in there and how hard will it be to rebuild? I have a full house tournament at 1PM tomorrow. I can get to the bowling center at 6AM...
    Re: Clutch whacked
    12-862138 clutch lever support kit. If you don't have one on it, you might need one. If you do have it, you may need to adjust it.
      Re: Clutch whacked
      If you see the clutch lever moving alot with the rattle, your worm shaft is most likely worn causing the drive disc assy to jump around.
      Do you have clutch support kits?
      If you find your worm shaft worn, you will be replacing it, And the drive disc also.
      Inspect the other parts as well to see if any need replacing...
      Mike
        Re: Clutch whacked
        Is that the grey metal bracket that can be installed on top of the clutch lever? If so, what is the proper adjustment (I have a few... but never adjusted one).
          Re: Clutch whacked
          Proper adjustment is where the clutch shoes ride in the middle and don't touch either side of the drive disc.
          Find it http://www.bowltech.com/content/btub...141#Post266141
          Upgraded Motor Contactor
          C1 Pinout drawing
          Finished the C1 drawing.
          Thanks Felix.
          If you see any...
