lift rod covers
  • lift rod covers
    can anybody tell me an easy way to change them
    Re: lift rod covers
    Now there is no longer the need to have a second person
    assist when installing a rubber ball lift rod cover. Simply
    attach the tool’s quick disconnect fitting to an air
    compressor and insert the adapter at the other end of the
    tool into the end of the rod cover. Control the air flow with
    the convenient foot control while having both your hands
    free to guide the cover on to your lift rods. This convenient
    tool comes with a 6 foot inlet and 6 foot outlet hose to allow
    plenty of unrestricted work area.
    Quality products part #
    38-4049
    Deluxe Rubber Ball Lift Rod
    Cover Installation Tool
    Also known as the puffanator works awesome and easy to use can do lift rods in minutes some people use baby powder some use dawn dish soap with this tool the only part thats tuff is the first curve but once past that you pump the foot peddal and it glides on nice an easy with little or no trouble at all can do as many as you want and not even break a sweat!
    Really love that tool heres the pdf file for the part number if needed!
    http://www.brunswickbowling.com/uplo...lity_33-43.pdf
    Thank You All! For All the prayers and and the out pouring of good spirits in my time of need greatly appreciated!
      Re: lift rod covers
      I use the urethane rod covers as they have been on about 9 years and still look great. They slip right on and easy to rotate once on so they last longer.
      I have the air tool mentioned above and it does work but would suggest investing in the urethane covers so you only need to change them once every 10 years or so.
      Drill
      David Bolt
      Champaign, IL
      USBC Silver Coach
      IBPSIA BOD
      IBPSIA Advanced
      Technical Certified
      Pro Shops
        Re: lift rod covers
        this link to some other techniques maybe helpful to you as well
        http://www.bowltech.com/forums/showt...130#post107130
        however you choose just keep at it the end result is a plus to keep ball calls down and bowlers happy!
          Re: lift rod covers
          No one seems to make urethane or foam covers for A's lift rods,
          Mike
            Re: lift rod covers
            Having m.s. there are alot of things that I cannot do now and most things are 10 times harder than they used to be. I pretty much cant us my right hand very well so I have had to fine different ways to do things. I have always used an air compressor attached to the cover, cleaned the rods well, and put baby powder on the rods and inside the cover. I do not have a foot pedal tool but plan on getting one. Even with someone working the air hose for me I no longer have the strength to pull the cover on. The other day I saw 2 covers that needed to be replaced so I cut them off and got everything ready to blow on when my night man arrived. Then I remembered a tool I saw years ago to put on covers. The closest thing I could find was a cast jogger arm without the large end bearing but with both internal snap rings still in it. Slipped it over the rod cover and blew the cover up to the top turn ,used the air with my bad hand and used the jogger arm to grip and ratchet the cover over the top and the rest of the way down. Finished that one and went and did the other. If I had a foot pedal I could say I did it one handed. It in no way was as easy as having 2 strong arms but for anyone that has trouble it might be something you might try.
            formerly dunsel
              Re: lift rod covers
              that foot petal tool is probaly very nice, but we have priced it at over $100.
              here's what i did. went to home depot, bought some pipe fittings that fit inside the rod rubber, a little t-valve quick shut off. put them together, hook 'em to your compressor. its not a 1 handed tool, but its great for the price of about $10
                Re: lift rod covers
                10 Years? Man I missed the boat on that. The last few years, the old tan gum rubber just doesnt seem to be holding up like it used to in the past. I think I will have to give them another look at. What about rocket rails ??
                Marty - Liberty Lanes
                56 Jap A-2's Qubica VDB's
                2 Kustodian Walkers
                  Re: lift rod covers
                  Rocket Rails anyone??
                  2 Kustodian Walkers
                    Re: lift rod covers
                    I've used them on one lane. They seemed to work well, however the center burnt down before I could judge their longevity.
                    Only complaint was that the zip ties tended to break more often than I liked.
                      Re: lift rod covers
                      Instead of baby powder I started using a product called glide. It comes in a can that you attach a spray bottle nozzle to. I shoot some on the lift rod and down into the new cover. With this stuff you can almost push it on without using air. I've been using it for a couple of years now. I haven't seen any sign of premature splitting due to the product eating the inside of cover.
                        Re: lift rod covers
                        We use WD-40! Worked for years with regular wear and tear.
                        [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                        Cody C. Stone. Frame Maker Intl.
                          Re: lift rod covers
                          Blo-'em on, withyour air compressor
                            Re: lift rod covers
                            Would you have any manufacture infomation on the glide that you use.
                            Steve H
                              Re: lift rod covers
                              i would like to know as well. if it makes it easier, why not.
                              Detector Rod Adjustment
                              The New Brunswick NXT
