turrent belt
  • turrent belt
    long turrent belt stops turning i touch it and then it works for a while help
    Re: turrent belt
    Is the belt in good condition? If not it may stick where it goes round the small drive pulley on the elevator especially if you are using a toothed belt, make sure there are no "strings" hanging off the belt which could get snagged up also you may not have enough tension on the long spring from the idler pulleys near the motor - but only increase this enough to maintain the drive on the belt.
    Make sure that the belt is running in ALL the pulleys. If you have put a new belt on they often will not "grab" on the small drive pulley until they become more flexible.
      Re: turrent belt
      I've seen that once. One of the slow speed pulleys had a bearing going bad that added just a little extra friction. A new pulley cured it.
        Re: turrent belt
        If the belt idles are froze up, the ones on motor mount, it could allow the tension to fluctuate after indexing and slip.
        Peanut
          Re: turrent belt
          Years ago I dealt with the exact scenario Peanut describes,the motor mount belt idler freezing up on occasion.
          I was able to fabricate nylon bushings for this pivot by taking the nylon bushing from a pit idler kit and cutting it in half,then coming up with a good bolt/locknut configuration to hold the idler down. Problem solved.
          "You can't burn out if you have never been on fire"
            Re: turrent belt
            Also if the tensioner spring is installed wrong and contacting the pulleys you will get extra tension and with enough time maybe some problems.
              Re: turrent belt
              All good post,
              I have also seen the small drive pulley on the jack shaft for that belt have large worn grooves in the V and cause it to slip...
              Mike
                Re: turrent belt
                Check the small drive pulley to see if the belt is bottoming out in the pulley. if it is...it can slip. Check it by doing this...(this is not the same pulley, but the idea is the same)
                  Re: turrent belt
                  Thats a good visual aid there Steve and a good point!
                  Thank You All! For All the prayers and and the out pouring of good spirits in my time of need greatly appreciated!
                  Oil in gutters
                  C1 Pinout drawing
                  Finished the C1 drawing.
                  Thanks Felix.
                  If you see any...
