I REALLY do not like messy wires...
  • I REALLY do not like messy wires...
    The title says it all. I hate hate hate working with a messy electrical box with useless wiring strewn about in them. So, this summer I was thinking about cleaning them up a bit since I've already got almost 1/2 of the machines changed over to relays for the time delay.
    Since doing the time delay delete I thought it would be a good idea to clean up some more wiring in the electrical box that isn't in use. I've seen many a centers with very few wires running through them and that's what I'd like to accomplish. Right now I'm running 32 lanes. 16 are A-2 Americans and 16 are A-2 Japs all on 230 Volts. We also have QAMF scoring (T-Vision with VDB's up front behind the TVs).
    My ultimate question is what can I eliminate from the electrical box? What can I upgrade to make it nicer to work in. HOW CAN I CLEAN THESE DAMN THINGS UP!
    Re: I REALLY do not like messy wires...
    best bet would be to PM "masternut" on here. he is the God of wiring up electrical boxes.
      Masternut is definitely the man to talk to
      her is one of his:
      I been using this pic as a base when replacing some of my
      older federal pacific contactors.
      Hope you don't mind me using your pic masternut.
      tim
        LOL, I think I recognize those masking units!
        Call if you need help. I may not answer but I will return your call when I get back. 757-653-7230
          Honestly I like that pic I am impressed. Electrical, electronics, and computer software development is a passion of mine. I have an old electrical box at home that I am tryin to make swapable so limited down time if something burns up. I would love to know who made that relay setup or where I can get one.
          BEWARE: Head Mechanic has tools and a temper
          CAUTION: Irritate me at your own risk
          http://www.bowltech.com/forums/impor...2012/laugh.gif
            Originally posted by strikezonemech
            I have an old electrical box at home that I am trying to make swappable so limited down time if something burns up...
            Kind of like an AMF chassis? That'd be cool. I tried that once using molex connectors. Sounded good in theory, but didn't work out so well on the machine as I had to deal with constant bad connections due to vibrations and it didn't look so good either due to the limited space in the area where the box ties into the wire channel.
            I still feel it is a sound idea. It should make replacing the box probably a 5 minute job. I am interested in seeing what you come up with.
              http://www.molex.com/molex/products/fami...wire_connectors
              Eventually when I get to doing electrical boxes I wanted to do a quick connect for the boxes for easy swapping. Maybe 1 larger multi-wire connector would be less likely to disconnect. Or the use of locking connectors
              Nick
                Cybernetic Solutions made a replacement electrical box that would mount under the work platform. It was wired using XLR connectors if I remember...making it easily replaceable.
                  Here is some of my handy work. (I LOVE ELECTRICAL STUFF)
                  "Efficiency is, doing better what is already being done!"
                    Steve, I have been wanting this for my machine. Do they still make them? Do you have any (contact) info or pictures. Please send to me.
                      Very nice Lonnie
                      MIke
                        Mine are a work in progress right now. I've redone 10, have to go back and redo the first 2 I did because I changed some things up.
                        First one I rewired:
                        What they look like now:
                        Depending on the age of your machines, I would strongly suggest changing the wiring out in the channels while you're at it, and also to your motor, and pinlight. I've found blackout switches on my machines that are useless b/c the wiring is dryrotted and shorted within itself, and I had a motor just last week where the powercord shorted within itself due to dryrot.
                          her is one of his:
                          tim
                          Sure man!
                          Here is a few before pics...this was an 40 minute in house conversion.
                          Peanut
                            Masternut, didn't I read on here at one time you either had a class, book, video, or something we could buy for that conversion? I wouldn't mind seeing what you've done different and possibly implementing to mine. I must admit that I've used that above pic of yours as a starting point..
                            I still prefer the cube style relays over the solid state ones though, in case of failure, no need to mess with the wiring to change one out.
                              i wouldn't mind buying a video if you were to make one. hell, i'd take a class if i could find the time.
                              Upgraded Motor Contactor
                              C1 Pinout drawing
                              Finished the C1 drawing.
                              Thanks Felix.
                              If you see any...
