Gearbox clutch and worm shaft
  • Gearbox clutch and worm shaft
    Is there a simple way to disassemble gearbox clutches for cleaning and lubing? I had someone do it 2 years ago but don't remember the best procedure. I also have a couple worm shafts with the fine thread alittle messed up. Is there a way to fix this.
    Thanks,Sid
    Re: Gearbox clutch and worm shaft
    I just remove the top pin and run a punch through it. Take the lower adjusting screw out, Take the 2 big nuts off the worm gear, take the punch out and pull the whole clutch assembly off and take to the washer,
    Might be able to find a thread cutter to rethread the bad ones. They are awfully fine.
    Pain is the weakness leaving body
    Courage is the other side of Fear
    RICK
      Brunswick makes a special tool for thread cleaning. It fits the worm threads perfectly, a must have tool. P/N 12-860660.
        PLEEEEEEEEEEEEEEEEEEEEEEEEEEASE make sure you take the machine down to either 90 strike or 270 (preferred) if you are going to take the wormshaft out. Trust me on this one
        [email protected] | jsebeny <--YouTube | Cell: 309-275-2453
          I use 90 and 10 standing pins, but that is a good warning.
            I used a 90 degree cordless angle drill from makita to help remove/install the bottom adjusting screw,made the job much easier than using a wrench/socket of any kind.
              Yeah definately set the deck on a box of pins or something like that. The first time I did a worm shaft the head mechanic told me to just put the machine in 2nd ball and the holding hook would catch the deck......BAD IDEA!!! The holding hook was adjusted too far out and didnt catch the deck. Very scary when that 4:1 arm swings around at you when you pop the worm shaft out. Needless to say I went back and replaced the holding hook because it was also excessively worn at the tip, probably from barely catching the deck during 2nd ball cycle for however long it was doing it.
                The thread chaser isn't a specialty tool. You can get it from most tool shops.
                  90 degrees on a full rack of pins.
                    You can also use lapping compound specifically formulated for the thread size you have. Cloverleaf is one company that makes it.
                    Basically you apply it to the threads, and use the nut to reform the threads. Takes a while but does work.
                      Or use the quick realese yoke pivots from zot....I love those!
                      Nick
                        really? i've thought of ordering 1 to try out when i get around to changing a clutch again. wasn't sure of those were that nice or not.
                          Changed all mine. thank god someone invented them
                            They are without a doubt a great help. If you are just cleaning the clutch and lubricating...you do not need to do any adjustment of the lower pin as it will already be set. Quick and easy...just one issue that I have seen. You will need to file the retainer every now and then. If you keep that spot lubed (I grease the roll pin before installing) you should never need to file it down.
                              Yes, the zot kit is the best and easiest to use. would never go back to the long screws. When i had them I always used an air ratchet.
                              RICK
                              • Howard
                                Rattle in gearbox
                                by Howard
                                Mode A gearbox has a deep rattle within. I suspicion one of the non- bearing components of the worm shaft is making the noise. Anyone else have experience with this? There...
                                10-06-2017, 03:23 PM
                              • StuBowlMan
                                Gearbox Clutch Problems
                                by StuBowlMan
                                I have a machine that, about once every three games, the gearbox clutch will engage (stop arm is out from under the clutch lever) but it will not start the gearbox. I have caught...
                                08-31-2006, 03:02 AM
                              • highball
                                Worm shaft nuts
                                by highball
                                Real quick. Are the two lock nuts at the end of the worm shaft reverse threaded? My gear box has seemed to lock up and I heard loosening them a bit might help
                                04-12-2012, 06:01 PM
                              • J_ROZ
                                Gearbox Clutch
                                by J_ROZ
                                Ive been having a hard time getting the clutch at 0. Every time i try to clean it and then reinstall it without removing the worm shaft i cant get it to 0. the 4:1 crank is always...
                                02-01-2011, 12:10 PM
                              • Guest's Avatar
                                Gearbox whine and lockup
                                by Guest
                                We have a machine which has had a loud whine come from the transmission when the clutch is engaged. Now it freezes up, requiring us to loosen the two 1 1/8 nuts about 5 turns...
                                04-27-1999, 04:33 AM
                              Super Bowl Funday!
                              Qubica BES-X Lane Advertising
                              Making TDM's adjustable.
