No cycle
  • No cycle
    Just got a call that 2 lanes aren't cycling unless done manually. I had them check to make sure its plugged in, and they were. Is there a voltage I can take somewhere to see if I should look at replacing the TDM or solenoid? I'd rather not change parts for no reason.
    [email protected] | jsebeny <--YouTube | Cell: 309-275-2453
    What is "IT"?
    The odds of both time delay modules going bad at the same time? Yea...I would be playing the lottery first.
    I am guessing it is in the scoring system or in a separate ball detect system if you are using one.
      Originally posted by Steve Stafford (JBEES) View Post
      What is "IT"?
      What pair is it???
      the ball detect may have got hit which means not cycle and since 12 strike uses those for scoring no scoring.
      it also maybe in the computer in the pedistal like it was with lane 11-12. Pat had broke some wires setting the monitor down.
        What is "IT"?
        the plug for the solenoid.
          Originally posted by TwinCityLanesFM View Post
          What pair is it???
          not a pair. lanes 3 and 6
            Scoring system or maybe rake down switches if you have those...
              i would still check the ball detects to make sure there working. it seems odd. i will be out there tonight for the sales tax
              MONITOR COLOR ISSUE!!
              Pin spot is off
