Ball Accelerator Electrical Issue
  • Ball Accelerator Electrical Issue
    When we turn on the pinsetter with the power on to the ball accelerator it pops the breaker. If we turn the switch off that links the power to
    the ball accelerator and the pinsetter we are ok. We can run the ball accelerator without a problem if we do not link the two. (turn the pinsetter on and
    then the ball accelerator on with its own power source.) We can not figure out where the short is to fix our problem. (Rookie mechanics) Any help would be a blessing.
    does it do it with both the machines or just one
    Bind in deck hook linkage
    GS-X table bolts/stud
    Other that...
