82-30 back end motor
  • 82-30 back end motor
    Rebuilt a motor all of a sudden it is making a whining sound - opened fill cap & it “burped” out some oil & is now quiet ? Could vent be plugged causing a “vapor lock” - any ideas
    Came in this morning - swapped out backend motor - same sound
      Ended up being the front roller
      Pins getting gouged
      Need Pinout for J2 & J22 (Masking unit)
      Hi Guys!
      I need some help. We're installing custom Masking units at a new location in PDX. Our sister center in Beaverton, OR has ZOT/ Horizon Ball indicator PCB's for the...
      Cracked Moving Deck
      I have a couple of pinsetters that have a cracked moving deck and I would like to replace them before leagues start. I have some spares that I can put in but I don't know how...
