Scoring bracket
  • Scoring bracket
    In search of bracket that attaches to sweep arm that triggers scoring - we have boss but assume its the same for accuscore also - L shaped with 2 holes to attach - anyone have any lying around or a part # THANKS
    Shot in the dark do you have 1 good one now?
    Take it to a laser cutting place?
    We got new AMF sweeps a few months back but the brackets they gave to attach weren't correct for our machines. Got 4 good ones from a guy in Dallas TX, took one to a laser cutting place locally and they cut us 20 for a fraction of the cost. Right around $60 actually since no welding was needed. 1 bend and 4 holes cut.
      I have a bunch of used ones at Stahls. Let us know if you need some. 651-322-2141.
        QubicaAMF still aseels the APS in Line Start Switch Assy 218-003-141
        Qubica BES-X Lane Advertising
        Ball Damage at my wits end
        GS-X table bolts/stud
        Other that...
        1:1 shaft wear
