Distributor head casting
  • Distributor head casting
    82-30 #030006846 head casting are they still available from someplace - any info appreciated THANKS
    Vantage makes them supposedly. I'll get you the number in a few once I get to work. The last 3 or 4 I got from there required a little filing. The side where all the gears go was too thick, and the bottom was too big to allow the whole thing to even spin. But little bit of filing to make sure it's round and it was perfect.
      Sorry was sick.
      The number is
      (806)995-3635
        in a pinch I can get almost anything I need from tucker in texas….
        Super Bowl Funday!
        Qubica BES-X Lane Advertising
        Making TDM's adjustable.
