82-30 chassis trouble
  • 82-30 chassis trouble
    Hi all, I am new to bowltech and I have a problem with my 82-30 chassis with omegatech modification. I have 1 chassis that will not recognize the reset switch cycle and 1 that the table continuously runs, I replaced the table ta switch but the problem is still there so I swapped with a good chassis and the problem went away. Help Please. Also does anyone know where I can get wiring diagram for 82-30 chassis.
    Re: 82-30 chassis trouble
    Tiger Tom, on the chassis that has a continous table run check your Contacts, sometimes they stick.
    Also check wires around and to the contacts, even inside the chassis. Make sure they are not making contact anywhere.
    I am not sure what you mean by reset cycle, do you mean 10th frame?
    Does the problem move with the chassis or does it stay on one lane? Could it be the 10th frame switch is not working or may have came unplugged.
    I am sure others will add other suggestions that may help.
    Hope I helped,
    P
    What?
      The problem stays with the chassis. when I say reset cycle I mean the backstop switch or the reset switch for cycling the machine.
        The machine won't cycle? Does the sweep drop?
        Can you switch boards to see if it may be in the omega board?
        If you are aren't sure just switch between the two to see if the problem moves with them, but really should switch with a known good board and chassis.
        There are lot of better techs that me on this site. I am still learning about chassis myself.
        If this don't work, keep posting, folks here will help you. If they can't they point in the right direction.
        P
        What?
          I should swap the omega tech board first like stated above.
          I do have drawings(without the omega tech board) but I'm in the netherlands, ask others first.
          If you got no help, PM me and we work something out.
          Good luck and welcome on the forum,
          Martin
          So it goes.
            tiger tom,
            Does the number on the omega board advance to step 1 when you press the cycle switch<
            Can you cycles the machine from the bowlers console?
            Can you cycles the machine from the cushion swicth?
            Also, as pman asks, does the sweep drop?
            "Smokey, this is not 'Nam. This is bowling. There are rules."
              Sweep does not drop and the stepper stays at 0 yes I have swaped boards and the problem stays with chassis. I have tried to get to cycle at bowlers console and back stop, also tried to reset chassis but no go there.
                You say the problem stays with the chassis, does that mean when you put that chassis on another machine you have the same problem? Have you checked the cr contacts for the sweep?
                If it stays on the same pinspotter with anoth chassis, is that table back to zero. The pinspotter will not cycle if the table is not back to zero.
                I've just remembered, i had this problem last year.
                http://www.bowltech.com/forums/showt...581#post186581
                I found it to be the ta switches. One of the microswitches was sticking. Changed the switch with a good spare and heypresto, no more problems. Try this and let me know how it goes
                I hope this helps you mate.
                  the lane with the table that continues to run was that the contacats on the cr was touching. I fixed that, now the chassis won't cycle when the cycle switch is hit, but it does click so it is recognizes that the switch is being engaged.
                    Ok, You fixed the chassis that had cont. table run. Correct?
                    Now you are working on the other chassis that does not cycle, correct. Sweep does not drop but you the hear the contacts clicking. If you put another chassis on that machine does it cycle?
                    If you put the chassis on another machine does the problem travel with that chassis?
                    Can the motors run if you lift the cam follower levers?
                    Anyone else have any ideas?
                    P
                    What?
                      The problem stays with the chassis, yes I can run the sweep and table using the cam levers. Also does anyone know where I can get wiring diagram for 82-30 chassis.
                        I don't have a wiring diagram that I know of or else I could fax it to you. I will look tomorrow when I go in the back and do my chores.
                        What?
                          are you positive the board doesnt go from step 0 to step 1. check your PR5(instructomat) is it pulled in? i bet it pulls in the second you put the chassis on the lane. if so theres your problem.
                          Russ
                            I have had trouble with PR5 in the past. Since I do not use instructomat, I took the wires that were supposed to make contact under normal conditions and soldered them together, then insulated the others, then removed the relay from the chassis. No more problems with the "instructomat" relay!
                            Gene Simmons for president!!!
                              I thought with a stepper chassis, the stepper should advance to step one (when cycled) even if the PR5 was pulled in. The PR5 prevents the sweep from running on Step 1 and 8. Does this not happen on the MK-30?
                              First thing I would do is swap the MK30 with another working chassis.
                              I would also look at the connections on the circuit boards mother board level 5 step 0. Possible this pin may have broke the solder connection or just a bad connection.
                              Oil in gutters
                              C1 Pinout drawing
                              Finished the C1 drawing.
                              Thanks Felix.
                              If you see any...
