Omega Tek
  • Omega Tek
    I have a machine that does not like the Omega Tek chassis right now, the sweep contactor chatters when the sweep runs. The machine runs fine with a stepper chassis or MP chassis. Checked the grounds on the SA and TA. The machine was working with an Omega Tek chassis, it is not in the chassis, any one seen this before?
    Re: Omega Tek
    We have seen this before. Check the contacts on your sweep relay. Most likely they are in bad shape and are not able to sustain contact.
    If you can afford to do it I highly recommend the BowlTronics SSR.
    Check them out. http://www.bowl-tronics.com/Ssr-amfx30.html
      Re: Omega Tek
      You can change your old relay with Siemens relay,work fine for me since a long time.
      If you want more infos PM me.
      82/30' S and me, it is a long story
        Re: Omega Tek
        One of the ground wires on the TA switches was bad. It was not broke but had a high resistance when checked with a meter.
          Re: Omega Tek
          Glad you found it! Thanks for reporting the cure!
            Re: Omega Tek
            Yes, Thanks Al,
            I like it when someone reports what the cure is/was. It is nice to know the answer to some of these trouble call questions.
            Bruno, can you give the part number for the Siemens relay? Is there any place in the States that sells them that you know of?
            Tracey
            What?
              Re: Omega Tek
              HI Tracy,
              Siemens relays are Industrial relays easy to find in France for around € 40 each.
              For reference, this week I would only to center Le Mans saturday
              If i can,
              I'll post pictures too.
              Bruno
              Super Bowl Funday!
              Qubica BES-X Lane Advertising
              Making TDM's adjustable.
