Chassis running Continously
  • Chassis running Continously
    No matter what Machine I put this Chassis on CR1 is pulled in
    Machine can be not running put this chassis on and it runs
    Check the wires and terminals on J36 and J37 in the chassis. If those two terminals short together it will turn CR1 on. Also make sure one or both aren't grounding.
    Louie
      Louie
      No Don't see a problem there
      Isnt J36 J37 to do with Instruct o Mat
        Yes, when they're grounded.
        Regards,
        Billy T
        [email protected]
          If you turn the "B" switch off in the back or the masking unit switch, does the chassis turn off?
            No?
              CR1 contacts are welded closed.
                Sorry No the open when chassis removed from the cradle
                  If problem stays with chassis ...
                  Make sure PR5 relay (instruct-o-mat) doesn't energize and contacts are open before and after plugging chassis into machine.
                  If CR1 becomes energized and PR5 is not then CR1 coil circuit (to J36) is wrong or T2 secondary circuit (to J37) is wrong.
                  Qubica BES-X Lane Advertising
                  Ball Damage at my wits end
                  GS-X table bolts/stud
                  Other that...
