Ball plug
  • Ball plug
    What is out there that is good. Don't want any of that 10 minute cure stuff that comes out like pound cake.
    I use Motiv HD. 8 hour dry time, cures crystal clear and takes color well. never had a problem with it.
    <---- You are getting sleepy, very sleepy. When you wake-up you will want to bowl more. . . .
      I like that way that sounds. Boss is currently sold on Vise urethane plug. I hate it. Trying to get him to change.
      • KenF2-R
        Ball plug
        KenF2-R
        Which brands of ball plug is everyone using out there,I have a ball work area that has high humidity and no air conditioning and a lot of our work cracks out within 6 months,...
        11-30-2000, 08:47 AM
      • DOUBLE D
        Ball plug
        DOUBLE D
        Need to order ball plug this week and was thinking of changing brands. I'm currently using DBA 321 and have been for quite some time. Just wanted to see what you guys are using...
        01-20-2010, 10:15 AM
      • RPSbowling (formerly Ryans Pro Sup)
        Ball Plug "Use By Date"???
        Can Ball plug go out of date?
        Well, i'm pretty sure it can, but I mean, just how quick?
        I am having some problems at the moment with my current batch...
        10-28-2006, 08:00 AM
      • SixBurghBowler
        Color Matching Plug
        SixBurghBowler
        I may be out of my mind (OK I know I am ) but I was pretty sick of cost of the color for my ball plug. I came up with two alternatives that are much less expensive and will give...
        10-03-2008, 11:32 AM
      • willey
        Ball Plug Brand
        willey
        O/K guys, I've checked the Archives, but I can't find a discusion on what is considered the best ball plugging brand.
        I'm asking, as I currently use Ebonite plugging, but...
        01-02-2005, 05:20 AM
      Detector Rod Adjustment
      The New Brunswick NXT
