Oil Extractors
  • Oil Extractors
    Hey All,
    We are looking to buy an oil extractor for our center. What product does everyone like the most. Detox, The Wave, the Revivor or is there something else?
    I was looking for an existing thread but could not find one.
    Thank for your opinion,
    John
    I use the Revivor temp set at 120, no problems. Works really well, no complaints.
    Every Man Must Think Something, So I'll Think I Will Have Another Drink. W.C. Fields
      I use the revivor also, set to 130 deg. Works perfect for 8 years allready. Easy money maker.
      We charge about $ 15,00 to extract the oil only and $ 22,50 to do an oil out and resurface.
        I use the revivor also, never had any issues with it. Just remember to change out the pads.
          Dang that is cheap... Get more for that combo bro! I get $40 for both...
            YES............^^^^^^^^^^^^^^AT LEAST THAT MUCH FOR SURE !!!!
              Is anybody using the Detox? That thing looks cool.
                We got one this summer. Works great. In the past I had used a cheap set of ovens. People can really see the results in the shop if you don't change the water, and on the lanes as well. I really like it, although sometimes the high pitch can bug some people.
                  Thanks for the input. That thing looks legit.
                  • emcnelis
                    Fire Permit to Oil Lanes?
                    emcnelis
                    So we are currently going through a thorough fire inspection process with the local fire department, and they are having us get a permit in order to clean and oil the lanes. This...
                    01-08-2018, 10:13 AM
                  • David Johnson
                    Green products
                    David Johnson
                    Are there any "Green" oils and cleaners on the market that anyone is aware of?? I believe brunswick sells a citrus based cleaner that is enviromentally friendly but...
                    11-03-2009, 12:02 PM
                  • kropy
                    Offense hv oil
                    kropy
                    I have been using Offense Hv for some time
                    now and in that time all the jugs that I have
                    open after shaking, it had a milky look to it.
                    The last case that I...
                    09-19-2005, 12:43 PM
                  • RGP
                    Syn-Pro Lane Oil
                    RGP
                    Has anyone tried this Syn-Pro lane oil. We had it at the last house I work at and it seemed to be Ok. Supposed to have less carry down and less break down. I don't think carry...
                    01-27-2004, 01:22 AM
                  • Fed - Up
                    IPA in legends oil?
                    Fed - Up
                    I know this is old news, but I was recently searching bowling patents when I came across the following and remembered this coming up in a bowltech thread.
                    So this is in...
                    12-24-2000, 12:05 PM
                  Detector Rod Adjustment
                  The New Brunswick NXT
