Full roller track issues
  • Full roller track issues
    I have a left handed full roller whose track has recently migrated through the finger holes. This is consistent with all of his equipment. The old track was a bit on the high side but was missing the middle finger hole by a good 1/2 in. He is bowling great but tearing up finger holes feverishly. Can a simple drilling adjustment help? Or is this simply a hand position issue?
    If it's broke it will work great.... until you stop watching it.
    If the diagnosis for him being a full roller is still correct and his equipment is still layed our full roller ( traditional pin to the right of his thumb in this case) then something has changed either his release is different or his axis tilt is now not full roller based. try having him throw a ball not layed out full roller and see if the track flares are through the palm. He may have "fixed" his full roller type roll. also is he damaging rubber finger grips or his beveled holes?
      I was thinking the same thing. I advised him to try out a conventionally drilled ball to see how it tracks. I may plug an old ball and drill it up for him and see how it tracks.
      His full rollers are chipping away the beveled holes and busting out the bridges.
        is he dropping it on the bridge? i have never seen a ball chip by just rolling over the holes before.
          I think it's a hand position issue. I worked a little with a right hander this week that was tracking over both finger holes. He was using a lot of wrist cup and generating a ton of revs and uncontrollable hook. I had him eliminate the wrist cup and after a few throws his track moved to a medium semiroller position with a moderate amount of hook. He was very happy with the changes. I don't know if this is the problem with your leftie full roller, but it's something you can look for. In the case of a full roller he may actually need to add a little wrist cup. -- JohnP
            I had a chance to drill up a "test" ball in conventional fashion. The results were a fairly high track but well clear of the thumb and finger holes. He must be coming over from the dark side. LOL
              I'm having the same exact issue. When you say "conventional" do you mean a label type drill? (cg in the center and pin in the 10 oclock position?
              I DID UM THE SAME!!
              • A2nut
                full roller
                A2nut
                hey guys,
                i want to know some suggested fitting techniques
                to get a person who throws a full roller to
                move the track away from the thumb and fingers.
                02-15-2007, 10:57 PM
              • Top Gun
                Drillings for a fubar full roller
                Top Gun
                I need help laying out a ball for a right handed cranker who tracks over his ring finger and thumb.
                he almost tracks on the lefty side of the ball and does not throw...
                04-16-2003, 07:45 PM
              • PKMech
                Full Roller?
                PKMech
                Had a friend (RH Bowler) come in today and practice. I couldn't help but notice he was tracking completely over the fingers and even some times tracking in the area normal for...
                02-05-2011, 12:13 AM
              • bowlgolf7
                Unique PAP - How to drill off it?
                bowlgolf7
                I have a customer that throws the ball with 1/2 his thumb in it,
                His pap measures out to be 7.5"x2.25"up
                He tracks over his middle finger...
                11-13-2009, 09:58 AM
              • scooter38
                Full Roller question
                scooter38
                I have a guy who throws a full roller. Is it better to get him a ball that gets into a roll sooner or one that skids. My assumption would be to get him a ball that rolls sooner...
                08-24-2011, 07:10 PM
              Detector Rod Adjustment
              The New Brunswick NXT
