Pnuematic duckpin lane, refresh
  • Pnuematic duckpin lane, refresh
    Hello, I’m putting some love into my dads mini duckpin lane... Upgrading it to arduino control (with a break beam sensor). I got it set up with a button for now and need to work on the timing, but it is playable for now! I have been using openscore and recently picked up one of Jimmy’s senor/board kits (highly recommended).
    No production, but this is how it sits for now... pins are manually loaded
    https://youtu.be/Z9lAy6qwRfs
    I also snagged a set of 1/2 scale pins and will be working on an auto pinsetter for that!
    Looking forward to contributing to the forum... I’ve been reading the thread pretty much since the beginning and watching Coasterp’s lane evolve to what it is now! You guys are awesome and I love seeing the progress.
    Looking forward to seeing what you come up with. The tilting pin deck is a cool idea.
      I saw in the description that you plan to use OpenScore 2.0
      I love the work Jimmy has done with that, but a better program (in my opinion) is ScoreMore. If you’d like to check it out, I’ll attach a link. It’s free
      https://sites.google.com/view/thinkc...ore?authuser=0
      Bind in deck hook linkage
      GS-X table bolts/stud
      Other that...
