1/2 scale Lane nearly finished
  • 1/2 scale Lane nearly finished
    Hello, I have been a lurker on the site for several months while my lane was under construction.
    For the most part the lane is fully functional with string pin setter and gravity ball return. The string setter works quite well. Maple heads with guardian and pine back end from a center that closed here in northern Ohio.
    Thanks to all of you that created threads which gave me ideas.
    regards
    ​​​​​​​Tom
    Looks good. Lets see some video of it in action.
      I have to figure out how to up load a video
      regards
      Tom
        Very cool! I wish I had the time and space to build something like this.
          It took approximately 2 months of spare time to get the lane to this point. Next is Auto score and large monitor. An IT friend is going to help me get it running on a Raspberry Pie.
          As for space...
          6' of approach
          From foul line to end of lane 26'
          Pit is 16"
          Regards
          Tom
            regards
            Tom
            Easy way to do it would just post to youtube and then place a link here.
            Super Bowl Funday!
            Qubica BES-X Lane Advertising
            Making TDM's adjustable.
