League definition not complete (Frameworx)
  • League definition not complete (Frameworx)
    I am using Framworx and Command network. Yesterday I was adding teams to our Sunday night league. After I added the teams I needed to get out to turn some lanes on for open bowlers. I got out and now when I try to go back into that league it aks me for number and I enter it and it gives the league but it won't let me do anything else. I selected change/view information and it tells me the "league definition is not complete hit enter to continue". I hit enter and it takes me back to the league screen. No matter what I select I get the same message.
    Any ideas?
    Were you adding more teams to an already established league, or just building it for the first time? If adding new teams you might need to go back to square one and make sure you have the number of teams set correctly and the number of lanes set. For example 12 teams and lanes 1-12. Then go to the schedule and make sure that is set up for the correct number of teams too!
      It wont let us in. It just comes up with the League Definition not complete.
        Is this a league you were just building? If so you might need to start over. If it's a league already in the system can you try cloning the league and get in it that way?
          Go to define a new league when it asks to enter a new league number enter the league that you are having issues with and it should take you to whatever definition question is incomplete
          The New Brunswick NXT
