Entering Pre-Bowled Scores?
  • Entering Pre-Bowled Scores?
    Hoping someone can help instruct me on if and how you can enter a pre-bowled score by a bowler into the system before the league actually bowls the night for which the score is to be used for?
    I know how to enter the score using the semi-automatic mode or manual mode but I am wanting to know if you can enter the prebowled score prior to league start up so it appears on the screen when the league is bowling the league scores for that particular date?
    Kevin
    If BLS has a pre-bowl score entered before you send to the front desk, it will think the week has bowled and you just have a bunch of scores not imported. So, enter the pre-bowl scores on the lanes after you send the league so the team has the score to use for winning/losing as they bowl. Then it will import with all the others for that week.
    Pins getting gouged
