Grill dying
  • Grill dying
    Wells in-counter grill. 24x18. One element is dead and the other one is on its last legs. This grill is in a custom cabinet with a lot of stainless steel. I would really like to get something that will drop in without major renovation.
    The local equipment place says they can't find anything and a pushing to sell us a table top unit. This would require completely scrapping the existing installation and rebuilding it from the ground up.
    What are the chances of just replacing the elements? I doubt if original replacements could be found but perhaps something close. Failing that how about a similar unit of the same dimensions.
    Any leads?
    You can have heater elements made. Had it done for a food warmer and fog machine. Not expensive either.
      Where would you go to have such a thing done?
        I had them done through a local electrical supplier here in AU, but if you Google "custom heater elements" you get a lot of places.
        Super Bowl Funday!
        Qubica BES-X Lane Advertising
        Making TDM's adjustable.
