I cleaned it real good 2 days ago .
  • I cleaned it real good 2 days ago .
    Click image for larger version
ID:	889183Click image for larger version
ID:	889184Click image for larger version
ID:	889185Click image for larger version
    It's better to remain silent and let people think you're stupid than to speak and remove all doubt
    Yuk
      Working on catering equipment is vile. Even if it does look clean on the outside you find layers of grease inside, and as soon as it gets on your hands you can't hold anything tightly.
      www.bigclive.com
        My question is how did you actually clean it? most fights grease/grease cutting products would throw up the white flag in defeat trying to get through that gelatinous ooze.
          Here are the after pictures . Zep Formula 50 , Razor blade and elbow grease . Not perfect but much better . Click image for larger version
ID:	885623Click image for larger version
ID:	885624Click image for larger version
ID:	885625Click image for larger version
ID:	885626Click image for larger version
          Pins getting gouged
