Update I cleaned it real good 2 days ago .
  • Update I cleaned it real good 2 days ago .
    Zep Formula 50 , razor blade and elbow grease .
    Click image for larger version
ID:	889201Click image for larger version
ID:	889202Click image for larger version
ID:	889203Click image for larger version
ID:	889204Click image for larger version
    It's better to remain silent and let people think you're stupid than to speak and remove all doubt
    Next time use something with Potassium hydroxide in it like this stuff http://cdn2.hubspot.net/hub/62331/Pr...=1493161077718
    This stuff is made by Swisher which is owned by EcoLab now.
    Table support assembly
    Foul Light LED Mod
