ice pick looking ball damage
  • ice pick looking ball damage
    Im having problems trying to find what's causing this kind of ball damage. I've checked lift rods and ball lift. Happens on both lanes of one pair. Any suggestions would be much appreciated. The ball in the picture is one of the worst I have seen. The damage varies from a few small marks to all the way around the ball like seen in the picture.
    It could be a subway track issue since it's a continuous line of marks and occurs on both lanes. I'd start looking from the dropsweep then continue up the lane to the power lift.
      If this is the only Ball damaged check out their Bowling Bag
      always doing my best.
        This has happened to quite a few balls. I checked the subway track and the ball lift yesterday. Wiped the subway tracks with a rag to see if it snagged on something sharp. Couldn't find anything. Today I'm looking at the Y switch and accelerator area. The switch track looks bent and it looks like it may be broken too. It isn't always completely around the ball like in the pic. Sometimes it's just a few spots.
          Check the cushions on your ball lifts C-track. Every single time i see ball damage happening on a pair instead of a single lane it turns out the C-track cushion are badly damaged/torn away, revealing the metal frame and bolts.
            Also check your kickbacks to make sure someone didn't use a fastener that is now coming out. Often forgot about since it isn't directly in the ball track.
              Check leather on transition track to see is there is something embedded in it.
                We have c90 returns check tensioner pulley nut inside return we have had balls wobble & nick on end of bolt
                  Well changed out the power lifts tracks on the pair and damage has gone away. Will still keep an eye still since I've had it disappear and then come back again. Thanks for all the responses.
                    Well bad news. Ball damage is back. Put new urethane tracks on the ball lift and still getting the same damage. I'm at a lost. Can't find any shavings at all. I filed down corners, cleaned ball wheels, checked and cleaned accelerator pan, checked track. I keep coming up with nothing. I don't know where to look or if I'm just overlooking something. Any help would be really appreciated. Our pro shop guy is even getting mad cause he keeps having to fix these balls and it's a pain to do.
                      What about the foul light units. Have you looked to see if there's something above that area of the track?
                        You could try sending a ball down the return when the building is quiet and with you standing mid way on the subway capping. Like Kanga said it could be foul light equipment hanging down. This happened to me one time and with the building quiet I could hear this faint thump. You just might hear something odd that will refocus your search.
                          I will be looking at it tomorrow when I come in. I know it's somewhere from the accelerator to the power lift. Hopefully when I come in the alley is empty.
                            Well I went back over everything again from the accelerator to the power lift. Still found nothing. But I went and checked around the lift rods area again and found what looks the be shavings. Shown in picture. Found the ball wheel edge is no longer rounded like it's suppose to be and the pit board cover had a rough spot on it where the ball comes out. Changed pit board cover and going to take the edge off the ball wheel. Hopefully this works.
                              I hope you found the cause but if not here is my thought . Try looking at the ball return it's self and the rubber bumpers at the end of it if it's a pair then there might be shavings under the return . My thought is the bowler may have rotated the ball to the finger holes then picked it up there might be a burr in just the right spot
                              • Tails
                                Ball Damage
                                by Tails
                                Have a pair getting pretty constant ball damage, it won't happen for a week or two, then it will have three in one league setting . I've narrowed it down from trap door up through...
                                07-27-2016, 06:34 PM
                              • Sherlock
                                Ball damage
                                by Sherlock
                                Where would you suspect ball damage to be coming from when it only affects the holes in the ball? So far they have replaced all 4 C track liners and both ball lift wheels in the...
                                02-01-2007, 09:51 PM
                              • Tails
                                Ball Damage
                                by Tails
                                Have a pair having occasional ball damage, have looked everywhere I can think of and it will still happen every few days or so. (not same lane as last post)
                                So far I have...
                                10-18-2016, 02:37 AM
                              • Larry
                                ball damage???
                                by Larry
                                I have a machine that damages ball only at the index finger. It looks like some thing gets right on the edge of hole and cuts into ball. It looks like taking a pointed tool and...
                                06-14-2000, 02:31 PM
                              • HAACK
                                ball damage
                                by HAACK
                                OK SAME OLD STORY BALL DAMAGE!
                                I'M GETTING GOUGE MARKS ON BALLS NOT THE SAME PAIR ALL OVER THE HOUSE. I DO NOT GET ANY OTHER DAMAGE JUST GOUGES 1/8" ISH WIDE...
                                09-27-2001, 03:14 PM
                              Oil in gutters
                              C1 Pinout drawing
                              Finished the C1 drawing.
                              Thanks Felix.
                              If you see any...
