Broken synthetic pins
  • Broken synthetic pins
    Has anyone seen a broken synthetic pins? this is a first for me.
    That’s a new one. Seen that with wood ones not twisters though.
    Might want to get ahold of the company that makes the pin.
      Yep, had same thing happen to a couple twisters, went back to amflite II after 1 year , for us it was too many sliding pins , and bowlers didn"t like the way they sounded , not to mention 4,9 pocket hits
        Some years back there was a user who was having the same issue. Posted some (what I thought were) funny videos of what would happen when the machines used the broken pins. His employer, however, didn't see the humor.
          We got Twisters about a year ago and we've already had 2 full boxes get warrantied for this issue. We still aren't 100% sure, but it looks like the pins' bounce makes them hit the lower-rear cross brace (GS-X). So far Classic has been quick to warranty these broken pin and since it's only happened to 20 pins in one year out of a 900-pin order hasn't been bad.
          • Scruff
            Synthetic Pins
            by Scruff
            My centre is contemplating on getting a set of synthetic pins. We are leaning towards the Lane Dynamics pin. Is anyone currently using or had synthetic pins, what is their pin...
            05-28-2002, 06:14 AM
          • Larry
            synthetic pins
            by Larry
            I read that ABC is using a synthetic pin in the tournament. Does anyone out there use this pin? What is your reaction to this new pin?
            thanks Larry ...
            03-27-2001, 04:54 PM
          • Guest's Avatar
            synthetic pins
            by Guest
            we have the new anvil lanes. we just recently got the new Twister synthetic pins. we have problems with a lot of out of ranges.is anyone else having this problem? If so have you...
            02-16-2000, 03:07 PM
          • the_blue_dragon
            Synthetic bowling pins
            by the_blue_dragon
            just want to know of anyone has tried these pins on a AMF pinspotter??
            and any thoughts??
            any good info is worth its weight in gold ...
            04-25-2008, 02:06 AM
          • kevin
            Offspot Pins - Synthetic Lanes
            by kevin
            What is available to help stop offspots that will last for awhile for Synthetic Lanes?
            The Pin Decks seem to be Clean.
            I'am Changing Lane cleaner for other reasons...
            04-11-2003, 11:45 PM
          MONITOR COLOR ISSUE!!
          Pin spot is off
