help with ball damage please - pic attached
  • help with ball damage please - pic attached
    any ideas on this damage? 82-70's and C-90 returns. This is only happening on lane 1 and does not happen consistently.
    similar damage to a 12 lb thrown by a senior bowler at maybe 7 mph
      here is another one...
        IN FLAT GUTTER IS WAR I B LOOKING
          Ball door ring screws.
            If only on lane 1 it has to be in lane, pit or ball door. I would check the door rings good as suggested. There should be ball material shavings near the area cutting ball.
              Pin deck edgeboard screw/nail or kickback plate screw/nail. You should be able to find ball shavings at the site. Might even be ball track issue, or right where ball enters lift.
                Check your ball track upfront, remove your ball return housing area and see if the rubber is off on the track. I have had similar issues and noticed that the rubber on the ball track was missing.
                The New Brunswick NXT
