Front Desk Reciept printer
  • Front Desk Reciept printer
    We are having issues with our front desk receipt printer, we have as-90 with the Brunswick command center version 532. Most of the time the receipt printer will not print and lock up the front computer, other times it will print a receipt with unrecognizable characters.
    You should be able to search on the internet for the model/make of your printer and find a manual for it and go through it for help
    Loading...
    Detector Rod Adjustment
    The New Brunswick NXT
