Chrome
  • Chrome
    I am using IE right now. Earlier I was using Chrome and this what I was getting.
    I'm using Chrome now and I have nothing.
    You may have some adware running.
    Walker B, Sanction Standard & Original K
      Found an extension in Chrome containing adware, deleted and is now ok. Name of extension is Ads by bobbylyrics, bad extension, underlines with double green lines and every time your arrow passes over it pop-up appears.
        This is a useful list of extensions to avoid if you want to avoid Malware
        https://discuss.howtogeek.com/t/warn...g-on-you/12394
        Table support assembly
        Foul Light LED Mod
