I have an drill press that is still working great, but the jig for securing the ball has developed slight motion due to wear. I would like to find a replacement jig, but have not found one. Attached is a pic. Would appreciate any leads. Many thanks.
rill press jig
by PitboyHow do I go about tightening up a drill jig? I have an Ebonite jig with the two point hold down levers. When I tighten the set screws for the pitches the jig will still whobble...
Channel: Pro Shop Discussion
09-06-2004, 01:02 PM -
Can anybody tell me what kind of drill press people are using to update their older style of jigs. I have an older jig and I want to update the drill press. I believe the augor...
06-02-2005, 11:39 PM -
by HEADWESTWe have an old Clausing drill press at my center that we did some ball drilling on yrs ago.It no longer has the jig so I bought a used one so I could do my personal equipment...
04-22-2008, 06:37 PM -
by sportlanesI have a drill press that will not wind back up because the spring on the press is not working properley and I cannot figure out how to install the new one. any suggestions on...
09-05-2010, 01:19 PM -
Bind in deck hook linkage
GS-X table bolts/stud
Other that...
Other that...
