Homemade tools
  • Homemade tools
    There are always a couple of spots you can cheat with tools. from cutting your wrench in half to give you a stubby wrench, to actually making something from scratch.
    wanted to give a forum to share your cost and time saving trick tools.
    Here's one i made just today.
    lift rod cover install tool. you ccan buy one of these for about $120. or you can go to home depot (or other hardware store) buy a quick shut-off T-valve (about $6), 4" length of 1/2" galavanized pipe (threaded) ($1.50), and the couplers to connect those to each other ($2). hook it up to your compressor, slip an end of your rubber on and hose clamp it.
    I re-rubbered 3 sets of rods today (been waiting on a tool) in about an hour, while chasing calls during league play.
    Gonna steal someone elses tip, just to make sure it gets here
    (thanx to the origanl poster of this)
    I know there is on guy that is showing off his deck cable adjustment tools, and since i've seen it, and will probaly make one of my own, i'll share that one.
    take the heads of two wrenches (depending on year and model it may be 9/16, or 1/2, or a combo of both) some flat stock bent into a U that fits onto your cable ends. weld them together and you can hold both nuts with one hand with adjusting with your other hand.
    Re: Homemade tools
    There's a cheaper way. Years before we had a compressor, we had fountain soda, so we borrowed a CO2 tank. No fittings needed. Hose clamp the end of the hose to the threads on the tank. If you open the valve too much, it'll blow the hose off the tank. If you use a fitting that the hose can hold to better, a regulator would be a good idea.
      Re: Homemade tools
      http://s271.photobucket.com/albums/jj141/bowler6051/
      Here is the deck cable adjusting tool c_thomas is refering to.
      My first picture didn't show the spring which holds the wrench together.
      jman
      WORK---is a 4 letter word!
        Re: Homemade tools
        I have a piece of 1/4" square key stock welded to a piece of 3/8" square key stock at a right angle. I use it for rake adjustments. The 1/4" piece is for setting the c lever gap, and the 3/8 is for rake board hight from the lane (I like em low).
        Really handy for quickly setting a rake adjustments.
          Re: Homemade tools
          Jman, Instead of using link code, copy the Img code and paste it into you post. Instant picture.
            Re: Homemade tools
            PJ
            Thanks for tip on posting pics. First timer at that.
            Wasn't sure which one to use.
            Have more pics of stuff I've made will post later.
              Re: Homemade tools
              Cool deck cable wrench, I like the spring idea, I have a similar one made with 9/16" deep sockets that are slotted to let the cable in.
              John
              John
              804-240-4982
                Re: Homemade tools
                Jman, thanx for getting that into here. thats the setup i mentioned earlier, and again i want to make sure the inventor has credit for it.
                hadnt noticed the pivot point and spring previously. gonna have to make sure i copy that setup when i get the chance.
                we have a mig welder, and i'm working on getting an oxy-aceytlyne setup. there's lot that can be fabricated with that pair.
                  Re: Homemade tools
                  Sorry, people, but I've deleted the post that included the images. The pictures are way too big! This makes it:
                  1) very hard to read the thread and
                  2) take a long time to load the page if you don't have broadband.
                  The FAQ (under How do I add an image to my message?) asks that you limit image size to 35K.
                  Here's a link with information on one way to http://www.bowltech.com/forums/showt...830#post188830
                  Deb
                    Re: Homemade tools
                    Sorry. Here they are:
                      Re: Homemade tools
                      http://i271.photobucket.com/albums/j.../guesswhat.jpg
                      Here is another of my strange tools. See if you can guess what it is used for.
                        Re: Homemade tools
                        Nice homemade tool!!! I presume the purple deck shield helps for cosmic bowling [img]/content/btubb/images/%%GRAEMLIN_URL%%/grin.gif[/img]
                        msbowl [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]
                          Re: Homemade tools
                          That's not purple that's PHANTOM! They match the GRAPE color scheme in the rest of the center! Those old aluminum shields have been patched so much some of them look like quilts!.
                            Re: Homemade tools
                            Now that one you could have made a little bigger, like 800 X 600.
                              Re: Homemade tools
                              Maybe this will be better.
                              guess what?
                              MONITOR COLOR ISSUE!!
                              Pin spot is off
