Homemade Tools ?
  • Homemade Tools ?
    Thought I d start a thread to see if anyone has "invented" tools to help them out ?
    Here's some I made earlier lol
    The white bar is for opening the finger cells without having to climb into the machine, and our selection of wooden ball return sticks, a metal bar for shifting the LBS over and another long finger cell opener lol
    Hey it makes life abit easier right ?!
    cant say that I have made any tools my self but we do have a few that came from someone who does make tools and my god they are a life saver, my two favorite are the jig to hold a ball lift while working on it (made by my boss), and also for working on a ball lift a wonderful tool that compresses and holds the spring so you can remove the belt and work on it with ease
    the Petersen classic its on my bucket list, yup I'm a nerd
      Cool do you have pics ? Used to have a tool to help fix the ball lift but I can't remember how it looked
        Someone made a nice hook for retrieving balls stuck in the subway (A-2 machines with carpet retarders) at a center I used to work.
        They took an old broom handle, attached a piece of strap steel, and belt it to a 90 degree angle with a slight hook at the end. Electrical taped the crap out of it, and the hook would sit nicely in the thumb hole so you can pull the ball thru the retarder without removing the key. That thing was a live saver.
          A pin fork works nice for opening cells as well after an offspot. Just need to be gentle.
            I will try to get some pics up soon
              I've modified some.
              Cut the handle off an AMF motor crank and use it n a 1/2" cordless drill.
              Built a modified 70/90 pinspotter cart that moves the weight to the center of the 4 wheel bottom cart.
              Built a GS table cable/solenoid tester box.
              Built a platform to take a 70/90 front end through a single door upright on a pallet jack.
              Had a Brunswick pinsetter cart built/modified so it can be used for GS.
              Made a removable front step to put on 70/90.
                Johnnes makes some really nice inventions
                  Why open the cells after an offspot? A well set up table shouldn't jam if you spot pins with the fingers closed, in fact, any time I set a table up, I make sure that the table will spot ok with fingers closed before I finish up.
                  I don't want to have to be called to a machine after a machine dropping pins due to closed fingers, seems to be a waste of offspot auto sweep reverse.
                    finally able to get a picture up of what makes doing ball lifts a heck of a lot easierClick image for larger version
                      I've been continually sorting, cleaning and organizing the back shop and I found this item buried in the back of a storage unit. I've got my guess as to what it might have been made for. What do you think it is?
ID:	884573Click image for larger version
                        [ATTACH=CONFIG]6124[/ATTACH][ATTACH=CONFIG]6125[/ATTACH]
                        Couldn't guess Pietenpol........but it looks really similar to something I keep around for when my pinchasers touch things they're not supposed to. lol
                          Belt clamping device for lacing distributor belt...?
                            That's exactly what I thought Steve
                              I agree, it looks like it could be used to clamp belts whilst they're on a dizzy. Sometimes it can be difficult getting the pin through the lacing
                              MONITOR COLOR ISSUE!!
                              Pin spot is off
