Results 1 to 2 of 2
    Join Date
    Nov 2002
    1714 N. Main, Mtn. Grove, MO 65711
    AMF Silver Bullet Magnum Software Prgm.
    Anyone out there using an AMF Silver Bullet Magnum machine with the computer program for setting up the lane patterns or programs. I recently bought a center and don't have the disk for the program. Would like to know if the program is any good and if any one out there has an extra copy they might be able to send me. Thanks Rusty.
    Join Date
    Nov 2002
    AMF Eastbrook Lanes, Grand Rapids, MI USA
    Re: AMF Silver Bullet Magnum Software Prgm.
    Call AMF and have them ship you the latest version with license. They can also send you set up specs for the Magnum too.
    Brian Conover
    Facility Manager
    AMF Eastbrook Lanes
