Register
Results 1 to 4 of 4
    Guest
    Bowling Ball Comparison Charts
    I'm looking for a reference chart of bowling balls. Not real techy but something very simple that can be posted in our shop that will assist customers in selecting a ball.
    Something like ball manu/model, lo, med or hi RG, react/non react, early/med/late hooking char, color, comments - goes long & hooks hard; mellow; good for spares; entry level; high tech. etc.
    We're new in the pro shop business and we always get questions like, What's a good ball for oil? How does this ball hook? What can I use on dry conditions? My ball hooks too early, what should I go to?
    Not that this chart is the answer but it is at least a start.
    In Search Of ........!
    Steve Mermelstein
    BowlingFans.com
  3. #3
    Guest
    Re: Bowling Ball Comparison Charts
    Thanks, a very nice page as well!
  4. #4
