Results 1 to 2 of 2
    Replacement Dodo Scale Weight?
    Sounds a massive stupid, [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] but the 1 pound weight for my (AMF) dodo scale has gone missing.
    Anyone know where I might be able to get a replacement?
    --- Just got a little center to call my own. Let someone else run the counter... I'll be running all over the place!
    Re: Replacement Dodo Scale Weight?
    Jim; Ive Got The INFO here,somewhere?
    But Until then; how about a pound of shot minus what you use to attach??????? [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
    T & J Bowling Products Corp.
    560 Birch St. 3
    Lake Elsinore, California, 92530
    909 674 7709
    Fax 909 674 7700
    Give'em a try... [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
    "Do-Do" Scale #3 071-001-019 [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
