Register
Results 1 to 3 of 3
    bowling alley wax
    This center opened in 1962 and I have a league bowler that says they used this stuff when it first opened.I do know that it was
    complete Brunswick install with Gold Crown and A's with the
    B-90 lane machine.Does anyone know when they stopped using
    this stuff.
    Ron
    Tech of the Year 2006
    Join Date
    Jun 2000
    Location
    Shelbyville, IN USA
    Posts
    7,797
    Re: bowling alley wax
    In a senior home in Frankfort, IN, there is still a sign on the wall that says 'how to wax a lane'. Although I never saw any container that said 'bowling alley wax'.
    This post is not an unpaid promotion of my business.
  3. #3
    There is still a product made called Butcher's Bowling Alley Wax. I never knew if that was just a name they gave it or they actually used it on alleys back in the days before the development of lane conditioner. The ad says made since 1880. I think now days it is used on furniture and wood floors.
