Register
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Changing a ball wheel belt for the first time.
    I was told there are videos on Bowl Tech on how to change a ball wheel belt on a Brunswick A pinsetter. If so, where do I fine them?
    Very visual...if you got pictures...send them too! Thanks!
    Quote Originally Posted by CurtisMcB View Post
    Here's some directions. Scroll down. http://www.bowltech.com/forums/showt...all+wheel+belt
    I'm going fishing and camping!
  3. #3
    I find it easier to leave the J bolts alone and remove the two bolts at the bottom (where you adjust the belt tension) to let the cross conveyor drop down.
    If you think my girlfriend can fight, you should see her box!
  4. #4
    Quote Originally Posted by Jack_Sparrow View Post
    I did the same.
  5. #5
    I always have lowered the cross conveyer by the j bolts. I cannot tell you how many bent, stripped, broken or incorrect hardware I have found within the j bolts.
  6. #6
    I also leave the J bolts there.
    "Some mistakes are too much fun to only make once" anon
  7. #7
    Members
    Join Date
    May 2012
    Location
    Gardnerville, Nevada USA
    Posts
    125
    For a long time, I would remove the bolt for the motor at the back, and always had a hard time getting it back in by myself. Finally realized that it is MUCH easier removing the nut/bolt in the front.
  8. #8
    A little off topic but I guess you could say I cheat a little bit. I use these http://www.grainger.com/Grainger/POW...t-V-Belt-5A547
  9. #9
    I used to take off the J bolts...but now I leave them on and take the adjusting bolts out. When I was teaching, I had one guy take the front of the cross conveyor off to get the belt around...I thought that was a bit much but it worked for him.
    I think he now takes off the adjusting bolts though.
  10. #10
    Members
    Join Date
    Sep 2006
    Location
    Spokane, Washington
    Posts
    1,471
    I always did the J bolts because I found that many installs where done incorrectly and the J bolts where not properly seated in the casting. The end of the J bolt has to go into the hole slightly to get the proper grip. Otherwise the J bolt bends, or the casting breaks.
    Just something I noticed here and there over the years, and it stuck like mud in my head (amongs't other weird things that get stuck there?).
