Register
Results 1 to 9 of 9
    Swapping 3QT's...
    I am in a situation where I have lent a couple of 3QT's to one of my sister centers and have been having issues with them booting up. Does anyone know if there are issues that might cause problems with booting when the spare 3QT's are installed?
    I know I need to push the programs to the replacement 3QT's as the software versions are slightly different due to a difference between 6 Box/F box. I have the F box while they have the 6 box.
    I know of no way to be able to push the programs without first booting the 3QT...but I am seeing issues arise when trying to boot. They will not boot up even if I take them back to my center. Has me very concerned about lending 3QT's between centers now.
    I am currently having a box come up with error code 208...F box failure. It can't see the F box because there are 6 boxes in the house?
    Any ideas?
    My center runs:6.11.02
    My sister center runs:6.11.02
    Steve, looking at the 3QT manual that I have (I dont have the stuff here though) on page 103-104 it tells you how to enter the HW setup for the 3QT box, depending if you have keyboards or monitors. I think thats the info you need. I found the manual on the Qubica/AMF portal in the scoring section, 3QT installation manual.
    Marty - Pro Bowl West
    56 Jap A-2's Qubica VDB's
    2 Kustodian Walkers
    http://s1196.photobucket.com/albums/aa408/a2mechanic
  3. #3
    Yes there has been issues with 3qt's booting up. Had a couple at a center doing this. Ended up replacing under warranty. Also make sure there is no other 3qts in center with the same serial number. They sent out a email once stating some had the same serial numbers. Not to use the number on the box but to use the number on the monitor when its powered up.
  4. #4
    I've had many issues on 3QT boots where it hangs after turning on. It hangs at the blue screen with the color spectrum across the top, and goes no further from there. I've even left them overnight, and still same screen in the morning.
    I swear, you just look at those things the wrong way and they crap out.
    Tech of the Year 2013
    Join Date
    Jan 2003
    Location
    "Do you know the way to San Jose?"
    Posts
    13,585
    I have not experienced any of these issues.
  6. #6
    Quote Originally Posted by Tablejam View Post
    Give it time...
    Join Date
    Jan 2003
    Location
    Posts
    13,585
    Actually, we have only had a couple of keypads fail, nothing else. I'm not counting the keypads as they get mashed on by customers I'm sure so that is expected.
  8. #8
    Our only issues have been about 9 or 10 BT boards. (About 22 months.)...But most of those were on the same lane.
    I can't even spell Brunsw-ick anymore!!!
  9. #9
    I had a few that appeared to be keypad failures...but it ended up being the ribbon cables coming loose at the keyboards. I created a "shim" from paper to insert between the connectors and have not had another come loose. Anybody else see this issue?
