Use Accuscore Plus Without Front Desk??
  • deb
    Re: Use Accuscore Plus Without Front Desk??
    Nope, I was on the beach collecting shells.
  • Kat
    Originally posted by wb8yjf
    Is that YOU bowling on lane 12, Deb?
    No, I think it's the person sitting at the back office computer trying to clean things up.
  • wb8yjf
  • deb
    To answer the EPROM questions, there are two flavors: SAS and SLB.
    SAS is for single keyboard bowler consoles with upper monitors.
    SLB (aka Low boy) is for dual keyboard consoles. SLB always has lower montors. Uppers can be added with no EPROM change.
    Configurations: http://www.bowlaway.com/asp_all..jpg
  • Ted
    I know where another used Purrfect Desk is. Only 6 months old.
    PM me if you want to know who to contact.
  • SVLFever
    Louie...can I ask who??? Send me a PM.
  • wb8yjf
    Used monitors should become more available as people switch to LCDs.
  • Louie_IV
    Originally posted by smalltownguy
    Not to burst your bubble, but the overhead monitors are obsolete also - you can get them fixed but it is getting harder...
    I had wondered this very thing. But, if they are both obsolete, then I guess it doesn't really matter which one they have. They would rather have overhead monitors anyway. They are going to be getting 2 spare monitors and it's only an 8-lane center, but I don't know how long those 2 are going to last??
    Louie
  • smalltownguy
    Originally posted by Louie_IV
    The main reason they are switching is because the small console monitors are always going bad and they are expensive. They were also told that the monitors are getting harder to find and going obsolete. Don't know if it's true or not though?
    Louie
  • wb8yjf
    If you pull the EPROM modules out of the CWC (the module has 3 lights on it, red, green, and sorta red, there are labels on the chips on that module. There are different versions of software for different configurations. If you are running them in standalone mode, you won't need the cables that plug into J2, J3, or J4 on the CWC. The lowboy version (what ya have now), has 2 keypads for each pair, the overhead version only has a single keypad. This is actually good for you as you will end up with an extra bowler terminal PCB when you convert. Examples of 'lowboy' software in the CWC usually have a 'SLB ###' on the labels. Overhead versions have a variety of versions, like 'SAS ###,'I agree with King, the overhead monitors are a pain in the butt. They are heavy, and you should have a scaffold to change them when they go bad. AMF has a conversion for LCD's, but it is pricey as it has to be purchased as a package - about $4K per pair, BUT it sure beats having to lug a 90lb monitor out of the air!
    Wells Gardner monitors should have a Wells Gardner label on the monitor chassis. You can tell if they are W-G monitors if they have one 'main' PC board under the tube. Zenith monitors are (IMHO) more reliable and easier to troubleshoot. There are 'hybrids' out there that have a W-G chassis and a Zenith picture tube, basically its a W-G monitor.
    I'm sending you a P.M.
    Jon
  • Louie_IV
    As always, answers bring up more questions.
    1. Please elaborate on the "Reprogrammed EPROMS". How do we get them reprogrammed? Or can we just switch chips? Or maybe it is easier to just swap out the whole CWC?
    2. What is this "WG" that sells the monitors?
    Louie
  • 8270king
    You can use the existing CWC's.
    You just need reprogrammed EPROMS for upper and lower monitors.
    If there is no communications cables it is in stand alone mode automatically.
    The small console monitors are available brand new in digital for under $150 from WG.
    All ours now have the same color throughout the house on A-l in 15 years.
    You need 110V in the ceiling and a way to hang the monitors.
    I would not put CRT monitors above under any circumstance.
    Hang LCD's and use a converter.
  • Louie_IV
    We are getting everything except the front desk system. The overhead monitors, bowlers consoles, CWC's, cables, etc...
    What would be easier? Just completely change out the CWC's or should we just swap the video boards in the existing CWC's?
    Sorry, but don't know what model number or EPROM version we are getting. Where is the EPROM chip located? Also don't know what brand of monitors we are getting.
    So, would this upgrade be pretty easy? Do we just have to mount the overhead monitors and run the cables to the back for the monitors? Should the existing cables going to the consoles be compatible with the new monitorless consoles?
    Also, what has to be done to switch it to "Stand-Alone" mode?
    Just wondering if this would be an easy do-it-yourself job or if we should seek someone with more scoring experience to do it? It doesn't sound too tough since they already have Accuscore in place.
    Thanks.
    Louie
  • wb8yjf
    Thats Accuscore plus. CWC 232-007-500. Are you getting the bowler terminal consoles as well? What version of software are you using now and what are they using at the other house (look at the EPROM module) The software will make a difference. You should have something like "SLB" something.
    It doesn't matter if the other system has a front desk (Advantage) system, you will just be operating the scorers in 'stand-alone' mode, ie: all the scoring commands & functions are typed into the CWC at the bowlers terminal console. The only problem I can think about at this time is that the 'lowboy' model they have now (13" monitors at the console) is that to use the uppers you will have to get the monitor control boards that come with the uppers. This is the board that breaks out the video from the CWC to the 2 monitors. The lowboy model has 2 cables that aren't compatible with the upper monitors, the overhead CRT's should have the correct board inside the housing. Other than that you should be good to go. BTW, what mfgr. are the upper monitors? Zenith or Wells Gardner?
    I hope I'm not forgetting anything, but happy hour ended an hour ago... [img]/content/btubb/images/%%GRAEMLIN_URL%%/grin.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/143.gif[/img]
    Jon
  • Fixumup42
    With Accuscore Plus you can still run the system the way it is now. Just make sure all of the cables are the right ones and if you take out the lower unit what are u going to do for a keyboard?
Help-broken Part
my crew was clearing a pin jam when the part fell on to the pin-deck. no enough experience to know where this is or what it's called. looking for help so we can order the part...
Qubica VDB Battery Replacement Part 2.
Greeting all.
I am sharing a link for a video, part 2, on how I replaced the battery in a Qubica VDB unit.
Thanks for looking.
Bolton454
Pin Damage
I have GSX pinsetters just over one year old. Just one of my machines is causing this damage to my pins. I have already adjusted the pin deflector boards to cover the bottom bolts...
Making TDM's adjustable.
I have some machines that the time delay cycles like right now when machine is triggered instead of the 3 sec delay. Would like to put in a potentiameter to correct this. Does...
1:1 shaft wear
Hi all....I have a pinsetter that knocks over pins at times when setting new pins. The moving deck shifts very abruptly right around 270 degrees. Instead of a smooth movement,...
