Advantage Scoring Printing
  • Advantage Scoring Printing
    We had a jr. bowler shoot 300. His MOM wants a print out of the score, however we do not have a printer at the desk. Is there a way to print the scores at the back office printer?
    AMF Advantage back office accu-score plus scoring.
    Re: Advantage Scoring Printing
    You can 'select printer' from special functions, but it will revert back after this print job.
      No luck on the "select Printer' option
        the printer may have a bunch of jobs backed upt in it any ideas on how to clear the que
          As nikki said, you may just need to http://www.bowltech.com/forums/showt...560#post169560. Try this first.
          If you have only one working printer the Back Office printer and the Ticket printer can be reconfigured to share the same device.
            cleared out the que, but still no luck on getting the print jobs to the backoffice printer
              Its going to be a sheet full of X's with his name at the front.
              I can print one of those, anyone can!
              If you cant remember why your still in it ...
              you've been there too long
                Here's one.
                I don't mean to make light of your problem. But today it is too easy to print something like this.
                Good luck at getting your printer to work.
                Does your backoffice printer work OK? You should be able to redirect your output to the back office with no problem.
                  I guess I should have been more specific.
                  The jr. bowler that I noted shot the 300 during a high school match with a rival high school. It was his first 300. I belive they wanted the print out with his team mates on it, with their scores as well.
                  I tried to redirect the print to the back office, but did not have any luck
                  Streamlane Mask Halo Lights
                  Baddest Tool Chest In Town
                  Adios, motor boater!
                  Aluminum Repair and Welding
                  http://aluminumrepair.com/...
                  Hi, guys.
                  check this jam...
                  the ball stuck the table up
