accuscore plus comm. problem
  • accuscore plus comm. problem
    I keep losing communication will my scoring, it is not just one pair, it will randomly lose comm. wil a pair or pairs of lane also the desk unit will freeze up or get real slow. when people are bowling, i will lose comm. but not the scores. I have cold started all cwc and the one at the desk
    --Eric
    Re: accuscore plus comm. problem
    What kind of front desk system?
      wyse wy-285
      --Eric
        That's the terminal p/n - do you have a CWC used as the front desk (AccuDesk) or do you have an Advantage system (desktop 'puter type)?
          cwc under the counter,
          --Eric
            OK - That's Accudesk. More than likely - this is your culprit:
            This is called the homerun box - all I/O to the terminal, printer, and the scoring goes through it. I'm sending you a PM right now regarding this.
            Jon
              GRRRR, I hate those darn things!! Out of 4 that I've had I had comm problems with all of them!! And they have enough current in them that they will shock you.
              Gene Simmons for president!!!
                Wb8yjf could you please e-mail me the same info as above please I am having the same problem
                Regards
                Stephen
                  Regards
                  Stephen
                  I'm PM'ing you now. These boxes aren't evil, they just get tired.
                    Huh? The Accudesk power is supplied from the Accu+ CWC BT power - about 8 volts AC.
                    If that bites - you don't want to be around me in a thunderstorm - I've been zapped 3 times It hurts. REALLY hurts.
                    Help-broken Part
                    Greeting all.
                    Thanks for looking.
                    Bolton454
                    Pin Damage
                    Making TDM's adjustable.
                    1:1 shaft wear
