ACCUSCORE PLUS
  • ACCUSCORE PLUS
    I have one pair that gives a ghost miss, changed cwc, ribbon cable, k-1, k-2, still comes and goes.
    Please define a ghost miss?
    Does it give a bowler a miss on 2nd ball without the bowler delivering a ball?
      1st ball or 2nd ball, mostly 1st ball, no ball thrown.
        Did you check the microswitches for the Tower Switch ass'y?
          yes, but i will swap out, see if problem moves
            its not the tower switch,still gives miss
              Am I correct in assuming the pinsetter is NOT cycling when a ghost score is posted?
                yes
                  No pinsetter has cycled and thats when the ghost miss shows. Have cycled machine from resets or throwing a ball, but the miss is delayed. the miss appears well past the time delay.
                    Is this one lane of the pair or both because in your original post you stated PAIR of lanes? If it is just one lane you could have the wires chaffed that go to the start switch or for you K1 K2 shorting out giving a start signal for the scorer to score even with no ball thrown.
                    70's MP/PBL/LBS,Q-Score
                    Prolane Walker sport
                      It is the pair,mostly the even lane.
                        OK this is not it but why not try it anyway.Try replacing the Eprom, you didn't mention that one.
                          Is a ball detect setup in use on the pair?
                            yes, bowltronics, but, I shut them off and it still does it. Also to keeth. I,ll try the
                            e-prom.
                              Might also want to check the cycle button wires at the power lift and the wires going underground to Pinsetter. (unless you converted those 10th frame buttons to RPO function)
                              Blue A2 Rebuild
                              Here are photos of the A2 that I just finished rebuilding and installing. Every single part on the machine came apart to be cleaned, painted, or replaced. All new rubber,...
                              Streamlane Mask Halo Lights
                              Hybrid (and EcoFriendly) Bumpers (2012)
                              It's been about 10 years since we first tried this - 46 lanes and still working fine, auto air bumper cylinders on the BankShot bumpers. Here are videos of a home install with...
                              Baddest Tool Chest In Town
                              Adios, motor boater!
                              Aluminum Repair and Welding
                              http://aluminumrepair.com/...
