Can anyone explain how to install the wiring from AccuScore XL to 82-30s? I have a friend who is having RPO issues and I would like to know what wire goes where. Thanks!!
AccuXL to 82-30 wiring
AMF supplied the RPO relay board to isolate the machine voltages from the scoring. I have seen a non-amf install where they elected to forgo the RPO relays, and they don't have related issues.
I do like isolating the machine/scoring, so I'd put them on.
Still need the start switch on the L side sweep rail.
Still need to wire the BE cycle button through the RPO input so it won't score.
Main difference I(vs Plus wiring) is being able to turn on the machine with the MI box by tying into 19 and 20 in the P box.
So, on the RPO board, the black and white hook to the black/white in the machine cable. The power (blue I think) goes to #18 for power for the board, and the black of that pair is ground, put on the board mounting screw.
The yellow and green are cycle from the board and go to J22 and 23. And the red is power throught the board to the scoring for the RPO and Start signal circuits. The purple and orange on the board aren't used and can be cut off near the board.
Power on is the green/black pair to the P box.
2nd ball hooks to 15 and 33..
