accuscore + question
  • accuscore + question
    can you interchange 7500 and 7250 cwc's?
    I run the 7500 and got some 7250 at a auction. Are the interchangable ?
    thanks in advance
    Yes you can use both but your new ones must be together and I have forgotten if they must be either at the front or the end of the line,most likely the end.You wont be able to run for example every other one or some other mix.
    PSST you either got 7350's or 7150's at the auction.
    70's MP/PBL/LBS,Q-Score
    Prolane Walker sport
      Keeth speaks the truth. Always does.
      The lower model number should be placed at the end of the comm line. In otherwords, on the pair with the terminator and then the one next to it, and so forth. Use your own eproms as the software version should be the same, regardless.
        Thanks Ted
          Ditto's guys. 7500 red at the BEGINNING of the line - always. The software has to be the same in all of them.
          What version of software are you using now? there are a lot of flaky versions floating around. 4.24 or 5.32 by any chance?
            Thanks for the info guys. It is a 7350 series just a typo on my part.
            my version on the eprom is 4.24
            I think in my spare time I'll hook 3 of them up at the end. that way I'll have plenty of spares on hand.
            thanks again chris
              Chris you may want to add them one at a time and test them for comm and functions like keyboard and scoring then keep adding. Just in case of anything you will know which one stopped all of your comm.
                good advice, thanks
